sfaust
Invalid Drive Error
I have a user that is getting this error when they run one of my installers:
S drive.jpg (17.49 KiB) Viewed 5553 times
The problem is that my installer doesn't reference an S drive anywhere (or anywhere that I have put in anyway). It also works on many other machines including mine that don't have an S drive so it seems to be something specific to this machine.
Can you tell me what would cause this and where would it be getting a reference to an S drive?
Re: Invalid Drive Error
Hello Faust,
This is, indeed, a strange behavior. This error is usually spawned when you try to reference a drive that does not exist on the user's machine. However, if you say you have never referenced such a drive in your project, I am not sure what may be the cause of this.
In order for me to further investigate this, could you please forward me the following:
- the installation log from the user's machine.
- the .AIP project
- the setup that was built using the earlier specified .AIP file
by e-mail at support at advancedinstaller dot com?
sfaust
Getting the log from the user. Sorry, for some reason it didn't notify me that there was a reply...
Hello Faust,
No problem. Just send the files over by e-mail when you get the log file from your user.
