blackpanda
VSTS signing code for exe file
I create a build job in VSTS for my installer and integrated AI project. At the final step, I want to sign the *.exe output by my cert. The signtool is only can sign the *.exe file but the *.msi embedded. This caused me an error when install the app. My cert is located in my Library as a Secure File.
Could you please help me to resolve this problem?
Thank you
Re: VSTS signing code for exe file
To avoid the EXE and MSI files signature mismatch issue at install time, then as a workaround you can double sign your setup package files. To do so you could create a test certificate and use it in "Digital Signatures" page of your setup project to sign the EXE, MSI and CAB files too. And then still keep your last EXE setup signing build steps.
blackpanda
Thank you
You are always welcome.
