Nikolay
Feature always installed when upgrade is being applied
I have an installation project wich installs 2 separate features.
The behavior defined for the in Organization page is as following:
- feature A - Installed (by default)
- feature B - Not installed
The problem occurs when product code of the main installation (major, minor or patch) is changed - then feature B behavior becomes "Installed" (when run installation).
Is there a workaround for this problem - I want my feature B to be always "Not installed" independently of upgrades.
Thanks in advance,
Nikolay.
Re: Feature always installed when upgrade is being applied
Hello Nikolay and welcome to our forums,
I have tested your scenario but I was not able to reproduce the behavior.
In order for me to further investigate this, could you please forward me a copy of your .AIP file by e-mail at support at advancedinstaller dot com? Also, a verbose log of the upgrade process would be really useful.
