jrahma
Beginner question about MSIX
I have downloaded the free edition and want to ask can I use MSIX on any Windows or it's just on Windows 10?
For example, can I use it on Windows Server as well?
Jassim
Re: Beginner question about MSIX
Hello Jassim,
The MSIX is available starting with:
- for Windows Server: Windows Server 2016 (Long Term Servicing Channel) version 1607.
- for Windows: Windows 10 version 1507.
TTbeelivio
Hello fellow,
I want to create an MSIX installer project for out UWP application build using Visual Studio 2019.
I use AI v17.0.0 and i wonder what should be the contents of the installer project?
When i try to create the project AI offers two options:
1 - create from scratch
2 - create from old package
STEP 1: Create MSIX from old package
When i go with create from old package there is only one option for me to choose so i choose the highlighted APPX as shown in the image below.
This gives an error like this:
STEP 2: Create MSIX from Scratch
1 - we input the name of the project and company
2- input paths
3 - choose project files
where i have placed the output content of the BUILD project from Visual studio (C:\...\project\bin\x64\Debug) which contains 5 appx packages of which
four of them are with suffix scale-100, 125, 150, 400 and the biggest in size Debug.appx as highlighted in the first image.
4 - finish the project and it builds automatically without any errors.
5 - i try to run the generated MSIX it opens a window which says "CANNOT OPEN APP PACKAGE" having reason: Error in parsing the app package.
so my next step was i tried to digitally sign and run the AI build again then it throw me an error like this:
Checking builds status
Build required.
[ Build_MSIX_APPX ]
Detecting Signtool compatibility
Detecting MSIX/APPX incompatible resources
WARNING: UWP Application. The application ConversionAgentRec.exe targets a .Net version lower than 4.6.1. You must re-target your application.
Creating resources.pri file(s)
Building MSIX package:
C:\Users\timotej.jakimovski\Documents\Advanced Installer\Projects\T2\Build_MSIX_APPXSetupFiles\T2-x64.msix
Preparing files
Preparing data for MSIX package
Creating AppxManifest.xml file
Validating AppxManifest.xml file
Creating registry file(s)
Creating [Content_Types].xml file
Creating MSIX file
Signing MSIX file
The digital signing of the MSIX/APPX failed. Error message: 'Done Adding Additional Store
Number of errors: 1
SignTool Error: This file format cannot be signed because it is not recognized.
SignTool Error: An error occurred while attempting to sign: C:\Users\timotej.jakimovski\Documents\Advanced Installer\Projects\T2\Build_MSIX_APPXSetupFiles\T2-x64.msix
File "C:\Users\timotej.jakimovski\Documents\Advanced Installer\Projects\T2\Build_MSIX_APPXSetupFiles\T2-x64.msix" can not be signed!
For a possible solution please check our Digital Signature FAQ from:
https://www.advancedinstaller.com/user- ... ature.html '
I am very confused about building this kind of installer and UWP project as well so any thoughts and suggestions are welcome.
Thank you
Hello Timotej,
In what regards the first point, unfortunately I can not say for sure why that happens. I have forwarded this to our development team for further feedback on this issue. I will let you know once we'll reach a conclusion.
In what regards the second point, please note that I have answered your forum thread here:
viewtopic.php?f=2&t=36104&start=15#p116385
