Sgbmad
Failed with return code:-532462766
Hi!
I'm using a Post-Building event to run a custom EXE and I get this error:
Running ******.exe
Application "*******.exe" failed with return code:-532462766.
I can check the EXE was executed without problems but I always get that error.
How can I avoid it?
Cheers.
Re: Failed with return code:-532462766
This could happen if your EXE app does return the related exit code (different that 0) on a successful exit. When we get an exit code different than 0 we interpret this as a failure. If this is the case, then to avoid the build operation failure you should make sure you uncheck the "Cancel build in case of a launch failure" option for your build event.
Sgbmad
Hi and thank you ;)
I don't think so....
The exe is a .net app returning the exit code.
I have tested the scenario using a sample .Net app and everything went fine in my tests. Accordingly with the exit code caught by our build process (-532462766 which in hexa is E0434352‬) this seems to be a .Net exception exit code.
Could you try to replicate the same issue using a small sample app? Or could you forward us by email to support at advancedinstaller dot com a download link for your custom EXE and a test case we can follow to replicate the behavior?
Sgbmad
Hi!
Well, I have found the reason finally. It was very very simple. If I remove the last "End" instruction, then the error dissapear! :)
Thank you anyway!
Cheers.
We're glad you sorted things out.
Sgbmad
Catalin wrote: ↑Fri Mar 22, 2019 1:45 pm Hello,
Thank you! ;)
You're always welcome!
