blackpanda
Serial Validation template
Hi
I am doing a Serial Validation for my installer. I used user defined DLL radio button and specified my DLL as your document says. It's OK, the problem is that I dont want to use the template <###-###>. Could you please tell me how to do that?
Thank you
Re: Serial Validation template
The template of the serial number can be changed from the top of the "Package Serial Validation" view, under the "Template" section.
blackpanda
Hi Eusebiu,
I didn't see any options not to use Template, I tried to delete the content in the Template textbox but it's not allowed
My problem is that my generated serial number is not a fixed pattern, for example it could be 1a2b3c-123456 or 1x2y-12345. That's why I don't want to use the template and just call validation function in my DLL. Could you please tell me how to define the template to meet the serial number validation?
Thank you
In order to avoid using a template for your serial number you can follow the steps below:
- go in the "Dialogs" page and select the "UserRegistragionDlg" dialog
- remove the "Masked Edit" box that is under the "Serial Number" text
- add an "Edit Box" control instead of it and set its property name to the "PIDKEY" property
- while the "Edit Box" is selected go to the "Control Conditions" tab and add the condition below:
  • Condition: SERIAL_VALIDATION = "TRUE"
    Action: Disable
- select the "Next" button of that dialog, go to the "Published Events" tab and select the "Show all events" option
- double-click on the "Validate ProductID property" event and set a false condition for it (e.g. 1=2)
- double-click on the "Execute custom action" event and set its condition to "1"
- in the "Table Editor" page select the "InstallExecuteSequence" table and set a false condition for the "ValidateProductID" row (e.g. 1=2)
- build and test your project
If you encounter other problems, just let me know.
blackpanda
Hi Eusebiu,
It didn't work. I did exactly what you mentioned. It still asked me to input text follow the template <###-###>
Result:
Indeed, there were some additional steps that I forgot to mention. Please find them in my previous post and let me know if they work.
blackpanda
Hi Eusebiu,
It's work! Thank you very much!
You're welcome. I'm glad it worked.
blackpanda
Now, if the serial number is incorrect, it does not show mesage like Invalid Serial Number or something like that but finish the installation with fault and impossible to go back.
blackpanda
Hi Eusebiu,
When I clicked Install button it showed message Invalid Serial Number and finish the installation. I have no idea why this message was showed there, I assumed that it's only showed in RegistrationDlg.
Could you please take a look?
Are you sure that you carefully implemented all the steps I mentioned in the post above? The "invalid serial number" message is displayed during the installation if the step below is skipped:
blackpanda
Hi Eusebiu,
It's already set like photo below
Is it correct?
This is what I got from the log file
Action 13:34:44: FindRelatedProducts. Searching for related applications
Action start 13:34:44: FindRelatedProducts.
MSI (s) (20:90) [13:34:44:291]: Skipping FindRelatedProducts action: already done on client side
Action ended 13:34:44: FindRelatedProducts. Return value 0.
MSI (s) (20:90) [13:34:44:291]: Skipping action: AI_DOWNGRADE (condition is false)
MSI (s) (20:90) [13:34:44:291]: Doing action: LaunchConditions
Action 13:34:44: LaunchConditions. Evaluating launch conditions
Action start 13:34:44: LaunchConditions.
Action ended 13:34:44: LaunchConditions. Return value 1.
MSI (s) (20:90) [13:34:44:291]: Skipping action: ValidateProductID (condition is false)
MSI (s) (20:90) [13:34:44:291]: Skipping action: AI_VALID_SERIAL (condition is false)
MSI (s) (20:90) [13:34:44:291]: Doing action: AI_EXIT_ACTION
Action 13:34:44: AI_EXIT_ACTION.
Action start 13:34:44: AI_EXIT_ACTION.
Invalid serial number.
MSI (s) (20:90) [13:34:46:432]: Product: CSAT -- Invalid serial number.
blackpanda
Could you guy please take a look on it?
Indeed, the error appears because another custom action checks the serial number during the installation. In order to avoid it, you need to add two "Set installer Property" custom action on the "Install Execution Stage" above the "Searches" action group as follows:
  • Property: SERIAL_VALIDATION
    Value: TRUE
    Condition: UILevel = 5
  • Property: ProductID
    Value: PIDKEY
Let me know if this helped.
blackpanda
It works!!!!
