nitin.mishra
Overwrite exiting MSI file
I am using AI with Jenkins. For some reason AI is not overwriting MSI file generated. If I delete the MSI , process does overwrite but not otherwise. I would like the file to be overwritten every time. How can we achieve the same ? I am using freeware with jenkins.
( When I only use the AI and 'RUN' it does overwrite).
Re: Overwrite exiting MSI file
Can you please delete the caching option for your setup project and let us know if this helped?
To do so just open your setup project (AIP file) in Advanced Installer. Then click on the [Options] toolbar button under the "Home" tab. Go to "Build" tab and uncheck the “Speed up builds by caching unchanged archives” option.
Save the project and test again the Jenkins build operations.
nitin.mishra
This does not work
nitin.mishra
Hey it does not. Its not overwritting.
Can you please configure the Advanced Installer build step to use our "rebuild" command? This should always force a rebuild operation. Just add the following command:
rebuild
in the "Additional Commands" field of the "Advanced Options" section of the AI build step of your Jenkins build.
Let us know if this helped.
nitin.mishra
This seems to be working. Thanks !!!
You are always welcome.
Glad we could help.
Just let us know anytime you encounter a problem.
