nellws
Installing / Registering fonts help!
Hi, attempting to create a package purely to install fonts onto user's systems centrally. I have imported the fonts (.ttf) into the "Files and Folders" section and clicked each one and selected "Register Font" from "Properties->Registration tab".
I have then build the msi and deployed using GPO on our Windows 2011 SBS server. I have a test machine that the msi gets installed on during startup but I cannot see any of the font files in the "Fonts" folder on the machine.
Any thoughts?
Many thanks!
Re: Installing / Registering fonts help!
Have you added your fonts under the following location in the "Files and Folders" page:
"Windows Volume" > "Windows" > "Fonts"
If so, did you leave the "Registration Name" field blank? Please keep in mind that this is the recommended approach if your font is a "True-Type" font (which in this case, it is).
Also, did this happen only on your test machine, or it happened on all machines that you have deployed the setup on?
nellws
Hi, yes installed to the specified directory and left "Registration Name" field blank. Have attached screen grabs.
Thx
This is a strange behavior. In order for me to further investigate this, could you please forward me the verbose log of the installation process of your MSI by e-mail at support at advancedinstaller dot com?
Please have a look on our "Automated logging with the Windows Installer Logging Policy" which I think you may find useful. This logging policy is particularly useful for troubleshooting Active Directory/Group Policy deployments (as in your case), in which case the installation is carried out without a user interface and there is no possibility to specify a command line for the MSI package.
nellws
Hi Catalin, have sent the logs as requested. Can you see any issues?
Hello Neil,
First of all, thanks for the sent log file. Indeed, it seems that none of your fonts gets installed. Your log file should contain something like this:
MSI (s) (74:88) [12:25:12:779]: Component: SomeFont.ttf; Installed: Absent; Request: Local; Action: Local
In order for your fonts to be copied over to the %windir%\Fonts folder.
This looks like a permission issue to me. In order to write to the %windir%\Fonts folder, you need higher privileges. Have you tried running the setup as administrator? In order to require administrator privileges for your setup, all you have to do is to go to "Install Parameters" page and check the "Run as administrator" option.
Quick note: here is what happens when you try to run a setup that tries to install and register a font without admin privileges:
