pforsbom
Custom Dialog validation
Hi
I have a custom dialog with a ListBox. This listbox is populated with some paths from registry using a custom action (writen in C#).
I have some questions:
1. User MUST select one value from the list before he can proceed. How can I disable the next button until a value is selected?
2. How do I retrieve the selected value? I want to use the selected path value to install some files from the installer package.
pforsbom
Re: Custom Dialog validation
I actually figured this out myself :D
On the "Next" button I added two Control Conditions:
1. MY_LISTBOX = "" - Disable
2. MY_LISTBOX <> "" - Enable
And using the selected value is just using the property of the listbox = MY_LISTBOX
Hi and welcome to our forums.
Indeed, your solutions are correct. If you have other questions, just let us know.
