cirio89
ErrorMessage custom action doesn't show my custom property
I've a custom action with a powershell script. Inside the script i've set a custom property :
AI_SetMsiProperty ERROR_ALREADYUPGRADE "Test"
In my "Display error message" popup I need to catch the variabile e show the error... but it's always empty,
The ERROR_ALREADYUPGRADE is not readed.
thanks.
Re: ErrorMessage custom action doesn't show my custom property
I'm not sure why you encounter this problem. Can you please send me the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com, so I can investigate them?
cirio89
I found a solution: my ERROR_ALREADYUPGRADE property depending by a user interface property and when my custom action is set on Execution Time Immediately the parameter it's not available.
When the custom action is set on "After the system ecc" is OK.
Now, i've another issue: the template action "Display error message" it's available only in "Immediately" scope
viewtopic.php?t=34495
And so i write a custom powershell script message box:
[System.Reflection.Assembly]::LoadWithPartialName('System.Windows.Forms')
[System.Windows.Forms.MessageBox]::Show($MessageBody,$MessageTitle,$ButtonType,$MessageIcon)
The message it's shown, however the popup it's behind of setup (attached). Can i fix it the position?
I'm afraid that I'm not aware of any solution of bringing that message box to the front. Also, I do not understand why your property is only available during the "commit" phase if it is actually set on the dialogs stage.
