It all depends on your needs.
If you are planning to create a patch, you should keep the same Product Code. If you plan to create a major upgrade, you should choose to generate a new Product Code. Windows Installer supports major application upgrades. A major upgrade is essentially the removal of an older product which is replaced by a newer product.
Please have a look on our
"Product Identification (ProductCode and UpgradeCode)" article which I think you may find useful.
