ragul
Command line updating the installer file
hi team,
i need a solution in command line interface build execution.
we are trying to automate the whole build until patch installer using advance installer.so i try to write a Bat file using the advance installer commands like addfile,folder,registry,etc..
but no command to add the sql script file in sql server connection in sql database.
kindly replay ASAP..
Re: Command line updating the installer file
Hello Ragul,
Unfortunately, we do not yet have support for adding an SQL script to your project through command line.
However, we already have it on our TODO list and I have increased its priority now that you have requested this.
Until then, I am afraid the only way is to add the SQL script through our GUI.
I will update this thread as soon as this feature will be implemented. However, I'm afraid I can not give you any estimation on when this will be ready.
Please let me know if there is anything else I could help you with.
This improvement has been added in version 21.1 of Advanced Installer.
