rsergeev
Order of xml tags has been changed
Hello!
I'm developing an outlook add-in and provide in installer manifest file - an xml file which contains some urls. These urls user inputs via installer UI and then these values go to manifest. The order of tags in this file matters. In .aip file I see the correct order of tags(see order_1.png)
, But after installation in a resulting file the order was changed somehow and I can't pass schema validation while uploading manifest to exchange server(see order_2.png).
This happens from build to build, but not every build. Version of Advanced Installer - 13.6. How I can handle this problem?
Re: Order of xml tags has been changed
Please accept our apologies for the delayed reply.
I am not sure why did you encounter this behavior. The XML elements should be created in the same order at install time as they are defined in the GUI of your setup project.
Can you please send us a copy of your .AIP (project file) which replicates this issue? Also, can you replicate the behavior on multiple machines? For testing purposes we always recommend to be used virtual machines with clean states so that when something goes wrong you can easily revert to a clean state of the virtual machine.
