olafurhj
Create MSIX/APPX build in project using command line
Hello.
I'm creating a project from the command line (following this video: https://www.youtube.com/watch?v=w8nE1MVYuDI)
When creating a project using the command line you will get a DefaultBuild that creates a .msi file of your project. What I'm trying to accomplish is creating a MSIX/APPX package for my project and from what I understand I need Build_MSIX_APPX to do that. I don't want to open my project and use a GUI to create that build in the project, is there a way to do this using the command line?
Thanks!
Re: Create MSIX/APPX build in project using command line
Unfortunately this is not currently supported by Advanced Installer command line feature. I have added this improvement on our todo list and hopefully it will be available in the future. Thank you for your suggestion.
When such command line option will be available we will update this forum thread.
