sjeslis
Cannot Launch An EXE From Finish button Of Exit Dialog
Using AI 15.8. I've tried "Launch EXE With Working Directory" and "Launch File" as a custom action w/o sequence.
Here's my setup for "Launch File":
Here's the log file error I keep getting now matter what settings I use:
Action 13:25:51: LaunchServiceManager.
Action start 13:25:51: LaunchServiceManager.
CustomAction LaunchServiceManager returned actual error code -532462766 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (c) (9C:6C) [13:25:52:766]: Note: 1: 1722 2: LaunchServiceManager 3: C:\Users\ADMINI~1\AppData\Local\Temp\MSI5D68.tmp 4: /EnforcedRunAsAdmin /RunAsAdmin /dir "C:\Program Files\Cicero Inc\Discovery Server\" "C:\Program Files\Cicero Inc\Discovery Server\ServiceManager.exe"
Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action LaunchServiceManager, location: C:\Users\ADMINI~1\AppData\Local\Temp\MSI5D68.tmp, command: /EnforcedRunAsAdmin /RunAsAdmin /dir "C:\Program Files\Cicero Inc\Discovery Server\" "C:\Program Files\Cicero Inc\Discovery Server\ServiceManager.exe"
MSI (c) (9C:6C) [13:25:54:750]: Product: Discovery Server -- Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action LaunchServiceManager, location: C:\Users\ADMINI~1\AppData\Local\Temp\MSI5D68.tmp, command: /EnforcedRunAsAdmin /RunAsAdmin /dir "C:\Program Files\Cicero Inc\Discovery Server\" "C:\Program Files\Cicero Inc\Discovery Server\ServiceManager.exe"
I'm running out of things to try since "Launched Installed File" seems to be broken in 15.8.
Scott Jeslis
Senior Software Engineer
Cicero, Inc.
sjeslis
Re: Cannot Launch An EXE From Finish button Of Exit Dialog
This might be our problem with the EXE, checking....
Scott Jeslis
Cicero, Inc.
sjeslis
This worked fine, built EXE was the issue.
Scott Jeslis
Cicero, Inc.
Hello Scott,
Thank you for your follow up on this. I am glad you sorted this out.
