threenub
Correctly Setting up EV Code Signing Certificate for AppX/MSIX build
Hi There,
We have recently deployed an EV code signing certificate in our build environment and I am having some trouble settings up the Publisher ID.
Now i have noticed that our subject in the code signing certificate differs slightly from others I have used in the past as it has additional RDNs:
  • SERIALNUMBER
  • 2.5.4.15
  • 1.3.6.1.4.1.311.60.2.1.3
It appears Advanced Installer 15.8 looks for a specific Regex pattern that prefaces the OID entries in my certificate with "OID.":
(CN|L|O|OU|E|C|S|STREET|T|G|I|SN|DC|SERIALNUMBER|Description|PostalCode|POBox|Phone|X21Address|dnQualifier|(OID\.(0|[1-9][0-9]*)(\.(0|[1-9][0-9]*))+))=(([^,+="<>#;])+|".*")(, ((CN|L|O|OU|E|C|S|STREET|T|G|I|SN|DC|SERIALNUMBER|Description|PostalCode|POBox|Phone|X21Address|dnQualifier|(OID\.(0|[1-9][0-9]*)(\.(0|[1-9][0-9]*))+))=(([^,+="<>#;])+|".*")))*
The issue i have is that my certificated does not list it in the subject this way, it simply the numbers (eg "2.5.4.15=Private Organization" rather than "OID.2.5.4.15=Private Organization").
This problem effectively prevents me from signing my AppX/MSIX packages so I am in a bit of a pickle. I know of other packages that are signed without the OID prefix, such as the Notification Manager for Acrobat Reader https://geelaw.blog/entries/adobe-reade ... o-windows/ (don't bother with the actual premise of the article haha)
Any help you can provide would be amazing..
threenub
threenub
Re: Correctly Setting up EV Code Signing Certificate for AppX/MSIX build
OK - I just retried the build with the "OID." prefix and it has worked.
For anyone else running into this problem all that needs to happen is you prefix OIDs with "OID.", such as:
CN=Company Code Signing Certificate, O=Organisation Name, L=City, S=State, C=AU, SERIALNUMBER=1234567, OID.2.5.4.15=Private Organization, OID.1.3.6.1.4.1.311.60.2.1.3=AU
Thank you for sharing with us the solution for your scenario.
As a side note, I want to mention that Advanced Installer uses the Microsoft's SignTool utility to sign the installation resources and this is a SignTool requirement, rather than an Advanced Installer specific one.
