Error Code 2732
Having trouble running Advanced Installer? Got a bug to report? Post it all here.
Post Reply
Guest
Error Code 2732
Post by Guest » Wed Jan 26, 2005 7:24 pm
I get an Error Code 2732 when running my built setup package with I include a .msm merge module, but do not get it without the module.
What is this error?
Is there an explanation of error codes somewhere?
Paul
PaulLimburg
Continue
Post by PaulLimburg » Wed Jan 26, 2005 7:26 pm
Now logged in as myself.
Thanks.
Cata
Contact:
Post by Cata » Thu Jan 27, 2005 4:30 pm
There is a problem with the msm. Can you give us details about it?
Cata
PaulLimburg
2722
Post by PaulLimburg » Mon Jan 31, 2005 12:38 am
Well, I see what I can do, I can't send it right now due to licensing issues.
Anything I can check?
Cata
Contact:
Post by Cata » Mon Jan 31, 2005 10:41 am
Run it with "Run and Log" and send us the log. Using ORCA, you can check the file sequencing, for the beginning.
Cata
PaulLimburg
Error Code 2732
Post by PaulLimburg » Mon Mar 21, 2005 8:32 pm
Cata,
I've tried again with the latest msi package included and here is the run log that results. There is a line that says:
DEBUG: Error 2732: Directory Manager not initialized.
What does this indicate?
Thanks for your help.
Paul
paul@LEAprint.com
=== Verbose logging started: 3/21/2005 11:16:30 Build type: SHIP UNICODE 3.00.3790.2180 Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (DC:20) [11:16:30:991]: Resetting cached policy values
MSI (c) (DC:20) [11:16:30:991]: Machine policy value 'Debug' is 0
MSI (c) (DC:20) [11:16:31:011]: ******* RunEngine:
******* Product: D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi
******* Action:
******* CommandLine: **********
MSI (c) (DC:20) [11:16:31:021]: Machine policy value 'DisableUserInstalls' is 0
MSI (c) (DC:20) [11:16:31:051]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi' against software restriction policy
MSI (c) (DC:20) [11:16:31:081]: Note: 1: 2262 2: DigitalSignature 3: -2147287038
MSI (c) (DC:20) [11:16:31:091]: SOFTWARE RESTRICTION POLICY: D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi is not digitally signed
MSI (c) (DC:20) [11:16:31:111]: SOFTWARE RESTRICTION POLICY: D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi is permitted to run at the 'unrestricted' authorization level.
MSI (c) (DC:20) [11:16:31:121]: Cloaking enabled.
MSI (c) (DC:20) [11:16:31:171]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (DC:20) [11:16:31:192]: End dialog not enabled
MSI (c) (DC:20) [11:16:31:242]: Original package ==> D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi
MSI (c) (DC:20) [11:16:31:252]: Package we're running from ==> C:\DOCUME~1\Paul\LOCALS~1\Temp\43226d3.msi
MSI (c) (DC:20) [11:16:31:262]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F1C07180-A490-4891-9733-C309F82C5428}'.
MSI (c) (DC:20) [11:16:31:322]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (DC:20) [11:16:31:332]: MSCOREE not loaded loading copy from system32
MSI (c) (DC:20) [11:16:31:342]: Machine policy value 'TransformsSecure' is 0
MSI (c) (DC:20) [11:16:31:352]: User policy value 'TransformsAtSource' is 0
MSI (c) (DC:20) [11:16:31:362]: Note: 1: 2205 2: 3: MsiFileHash
MSI (c) (DC:20) [11:16:31:372]: Machine policy value 'DisablePatch' is 0
MSI (c) (DC:20) [11:16:31:382]: Machine policy value 'AllowLockdownPatch' is 0
MSI (c) (DC:20) [11:16:31:392]: Machine policy value 'DisableLUAPatching' is 0
MSI (c) (DC:20) [11:16:31:412]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (c) (DC:20) [11:16:31:422]: APPCOMPAT: looking for appcompat database entry with ProductCode '{F1C07180-A490-4891-9733-C309F82C5428}'.
MSI (c) (DC:20) [11:16:31:432]: APPCOMPAT: no matching ProductCode found in database.
MSI (c) (DC:20) [11:16:31:442]: Transforms are not secure.
MSI (c) (DC:20) [11:16:31:452]: Command Line: CURRENTDIRECTORY=D:\DWF\LEA\DwfConvert\Installer CLIENTUILEVEL=0 CLIENTPROCESSID=1500
MSI (c) (DC:20) [11:16:31:462]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{B8281B75-6136-4DE5-A232-EB836CC79752}'.
MSI (c) (DC:20) [11:16:31:472]: Product Code passed to Engine.Initialize: ''
MSI (c) (DC:20) [11:16:31:482]: Product Code from property table before transforms: '{F1C07180-A490-4891-9733-C309F82C5428}'
MSI (c) (DC:20) [11:16:31:492]: Product Code from property table after transforms: '{F1C07180-A490-4891-9733-C309F82C5428}'
MSI (c) (DC:20) [11:16:31:512]: Product not registered: beginning first-time install
MSI (c) (DC:20) [11:16:31:522]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (c) (DC:20) [11:16:31:532]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (c) (DC:20) [11:16:31:542]: User policy value 'SearchOrder' is 'nmu'
MSI (c) (DC:20) [11:16:31:552]: Adding new sources is allowed.
MSI (c) (DC:20) [11:16:31:562]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (c) (DC:20) [11:16:31:572]: Package name extracted from package path: 'DWFConvert Setup.msi'
MSI (c) (DC:20) [11:16:31:582]: Package to be registered: 'DWFConvert Setup.msi'
MSI (c) (DC:20) [11:16:31:592]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (c) (DC:20) [11:16:31:612]: PROPERTY CHANGE: Modifying ALLUSERS property. Its current value is '2'. Its new value: '1'.
MSI (c) (DC:20) [11:16:31:622]: Machine policy value 'DisableMsi' is 0
MSI (c) (DC:20) [11:16:31:632]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (c) (DC:20) [11:16:31:642]: User policy value 'AlwaysInstallElevated' is 0
MSI (c) (DC:20) [11:16:31:652]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (c) (DC:20) [11:16:31:662]: Running product '{F1C07180-A490-4891-9733-C309F82C5428}' with elevated privileges: Product is assigned.
MSI (c) (DC:20) [11:16:31:672]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'D:\DWF\LEA\DwfConvert\Installer'.
MSI (c) (DC:20) [11:16:31:682]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '0'.
MSI (c) (DC:20) [11:16:31:692]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1500'.
MSI (c) (DC:20) [11:16:31:712]: TRANSFORMS property is now:
MSI (c) (DC:20) [11:16:31:722]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (c) (DC:20) [11:16:31:732]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Application Data
MSI (c) (DC:20) [11:16:31:742]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Favorites
MSI (c) (DC:20) [11:16:31:752]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\NetHood
MSI (c) (DC:20) [11:16:31:762]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\My Documents
MSI (c) (DC:20) [11:16:31:772]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\PrintHood
MSI (c) (DC:20) [11:16:31:782]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Recent
MSI (c) (DC:20) [11:16:31:792]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\SendTo
MSI (c) (DC:20) [11:16:31:822]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Templates
MSI (c) (DC:20) [11:16:32:003]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data
MSI (c) (DC:20) [11:16:32:173]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Local Settings\Application Data
MSI (c) (DC:20) [11:16:32:193]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\My Documents\My Pictures
MSI (c) (DC:20) [11:16:32:203]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
MSI (c) (DC:20) [11:16:32:213]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
MSI (c) (DC:20) [11:16:32:223]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs
MSI (c) (DC:20) [11:16:32:233]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu
MSI (c) (DC:20) [11:16:32:243]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop
MSI (c) (DC:20) [11:16:32:253]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Start Menu\Programs\Administrative Tools
MSI (c) (DC:20) [11:16:32:263]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Start Menu\Programs\Startup
MSI (c) (DC:20) [11:16:32:283]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Start Menu\Programs
MSI (c) (DC:20) [11:16:32:293]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Start Menu
MSI (c) (DC:20) [11:16:32:303]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\Paul\Desktop
MSI (c) (DC:20) [11:16:32:313]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
MSI (c) (DC:20) [11:16:32:323]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (c) (DC:20) [11:16:32:333]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 20
MSI (c) (DC:20) [11:16:32:343]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (c) (DC:20) [11:16:32:353]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (DC:20) [11:16:32:363]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'Paul Limburg'.
MSI (c) (DC:20) [11:16:32:383]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (c) (DC:20) [11:16:32:393]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'L E A'.
MSI (c) (DC:20) [11:16:32:403]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\DOCUME~1\Paul\LOCALS~1\Temp\43226d3.msi'.
MSI (c) (DC:20) [11:16:32:413]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi'.
MSI (c) (DC:20) [11:16:32:423]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'D:\DWF\LEA\DwfConvert\Installer\'.
MSI (c) (DC:20) [11:16:32:433]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'D:\DWF\LEA\DwfConvert\Installer\'.
MSI (c) (DC:AC) [11:16:32:443]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '3.00'.
=== Logging started: 3/21/2005 11:16:32 ===
MSI (c) (DC:20) [11:16:32:513]: Note: 1: 2262 2: PatchPackage 3: -2147287038
MSI (c) (DC:20) [11:16:32:523]: Machine policy value 'DisableRollback' is 0
MSI (c) (DC:20) [11:16:32:533]: User policy value 'DisableRollback' is 0
MSI (c) (DC:20) [11:16:32:543]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
MSI (c) (DC:20) [11:16:32:553]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (c) (DC:20) [11:16:32:563]: Doing action: INSTALL
Action start 11:16:32: INSTALL.
MSI (c) (DC:20) [11:16:32:634]: UI Sequence table 'InstallUISequence' is present and populated.
MSI (c) (DC:20) [11:16:32:644]: Running UISequence
MSI (c) (DC:20) [11:16:32:654]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
MSI (c) (DC:20) [11:16:32:664]: Doing action: LaunchConditions
Action start 11:16:32: LaunchConditions.
MSI (c) (DC:20) [11:16:32:694]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
Action ended 11:16:32: LaunchConditions. Return value 1.
MSI (c) (DC:20) [11:16:32:714]: Doing action: PrepareDlg
Action start 11:16:32: PrepareDlg.
Info 2898. DlgFont8, Tahoma, 1
Info 2898. VerdanaBold13, Verdana, 1
DEBUG: Error 2826: Control BottomLine on dialog PrepareDlg extends beyond the boundaries of the dialog to the right by 7 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: PrepareDlg, BottomLine, to the right
Action 11:16:33: PrepareDlg. Dialog created
Action ended 11:16:33: PrepareDlg. Return value 1.
MSI (c) (DC:20) [11:16:33:295]: Doing action: FindRelatedProducts
Action start 11:16:33: FindRelatedProducts.
Action ended 11:16:33: FindRelatedProducts. Return value 1.
MSI (c) (DC:20) [11:16:33:325]: Doing action: AppSearch
Action start 11:16:33: AppSearch.
MSI (c) (DC:20) [11:16:33:355]: Note: 1: 2262 2: AppSearch 3: -2147287038
Action ended 11:16:33: AppSearch. Return value 1.
MSI (c) (DC:20) [11:16:33:375]: Doing action: CCPSearch
Action start 11:16:33: CCPSearch.
MSI (c) (DC:20) [11:16:33:395]: Note: 1: 2205 2: 3: CCPSearch
MSI (c) (DC:20) [11:16:33:405]: Note: 1: 2228 2: 3: CCPSearch 4: SELECT `Signature_` FROM `CCPSearch`
Action ended 11:16:33: CCPSearch. Return value 0.
MSI (c) (DC:20) [11:16:33:425]: Doing action: setUserProfileNT
Action start 11:16:33: setUserProfileNT.
MSI (c) (DC:20) [11:16:33:455]: PROPERTY CHANGE: Adding USERPROFILE property. Its value is 'C:\Documents and Settings\Paul'.
Action ended 11:16:33: setUserProfileNT. Return value 1.
MSI (c) (DC:20) [11:16:33:475]: Skipping action: SetAllUsersProfileNT (condition is false)
MSI (c) (DC:20) [11:16:33:485]: Doing action: setAllUsersProfile2K
Action start 11:16:33: setAllUsersProfile2K.
MSI (c) (DC:20) [11:16:33:505]: PROPERTY CHANGE: Adding ALLUSERSPROFILE property. Its value is 'C:\Documents and Settings\All Users'.
Action ended 11:16:33: setAllUsersProfile2K. Return value 1.
MSI (c) (DC:20) [11:16:33:525]: Doing action: ResolveSource
Action start 11:16:33: ResolveSource.
MSI (c) (DC:20) [11:16:33:555]: Note: 1: 2732 2: 0
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2732. The arguments are: 0, ,
MSI (c) (DC:20) [11:16:39:423]: Product: DWFConvert -- The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2732. The arguments are: 0, ,
Action ended 11:16:39: ResolveSource. Return value 3.
MSI (c) (DC:20) [11:16:39:453]: Doing action: FatalError
Action start 11:16:39: FatalError.
DEBUG: Error 2826: Control BottomLine on dialog FatalError extends beyond the boundaries of the dialog to the right by 7 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FatalError, BottomLine, to the right
Action 11:16:39: FatalError. Dialog created
MSI (c) (DC:AC) [11:16:39:944]: Note: 1: 2731 2: 0
Action ended 11:16:43: FatalError. Return value 2.
Action ended 11:16:43: INSTALL. Return value 3.
Property(C): DiskPrompt = [1]
Property(C): InstallMode = Typical
Property(C): UpgradeCode = {97174315-9D74-464C-B18A-B38900790078}
Property(C): IAgree = No
Property(C): ButtonText_Back = < &Back
Property(C): ButtonText_Browse = Br&owse...
Property(C): ButtonText_Cancel = Cancel
Property(C): ButtonText_Exit = &Exit
Property(C): ButtonText_Finish = &Finish
Property(C): ButtonText_Ignore = &Ignore
Property(C): ButtonText_Install = &Install
Property(C): ButtonText_Next = &Next >
Property(C): ButtonText_No = &No
Property(C): ButtonText_OK = OK
Property(C): ButtonText_Remove = &Remove
Property(C): ButtonText_Repair = &Repair
Property(C): ButtonText_Reset = &Reset
Property(C): ButtonText_Resume = &Resume
Property(C): ButtonText_Retry = &Retry
Property(C): ButtonText_Return = &Return
Property(C): ButtonText_Yes = &Yes
Property(C): CompleteSetupIcon = completi
Property(C): CustomSetupIcon = custicon
Property(C): DefaultUIFont = DlgFont8
Property(C): DlgTitleFont = {&DlgFontBold8}
Property(C): ErrorDialog = ErrorDlg
Property(C): ExclamationIcon = exclamic
Property(C): InfoIcon = info
Property(C): InstallerIcon = insticon
Property(C): INSTALLLEVEL = 3
Property(C): Progress1 = Installing
Property(C): Progress2 = installs
Property(C): PROMPTROLLBACKCOST = P
Property(C): RemoveIcon = removico
Property(C): RepairIcon = repairic
Property(C): Setup = Setup
Property(C): ShowUserRegistrationDlg = 0
Property(C): Wizard = Setup Wizard
Property(C): VIEWREADME = 1
Property(C): BannerBitmap = large_white_banner.bmp
Property(C): COMPANYNAME = L E A
Property(C): USERNAME = Paul Limburg
Property(C): VersionNT = 501
Property(C): DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property(C): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(C): SourceDir = D:\DWF\LEA\DwfConvert\Installer\
Property(C): CTRLS = 3
Property(C): ProductName = DWFConvert
Property(C): ALLUSERS = 1
Property(C): ARPCONTACT = Limburg Engineering Associates
Property(C): ProductVersion = 0.2.0
Property(C): SecureCustomProperties = OLDPRODUCTS
Property(C): ProductCode = {F1C07180-A490-4891-9733-C309F82C5428}
Property(C): ARPPRODUCTICON = controlPanelIcon.exe
Property(C): ARPURLINFOABOUT = http://www.LEAprint.com
Property(C): DialogBitmap = large_white_dialog.bmp
Property(C): Manufacturer = Limburg Engineering
Property(C): ProductLanguage = 1033
Property(C): ALLUSERSPROFILE = C:\Documents and Settings\All Users
Property(C): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(C): AppDataFolder = C:\Documents and Settings\Paul\Application Data\
Property(C): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(C): CommonFilesFolder = C:\Program Files\Common Files\
Property(C): FavoritesFolder = C:\Documents and Settings\Paul\Favorites\
Property(C): FontsFolder = C:\WINDOWS\Fonts\
Property(C): LocalAppDataFolder = C:\Documents and Settings\Paul\Local Settings\Application Data\
Property(C): MyPicturesFolder = C:\Documents and Settings\Paul\My Documents\My Pictures\
Property(C): PersonalFolder = C:\Documents and Settings\Paul\My Documents\
Property(C): ProgramFilesFolder = C:\Program Files\
Property(C): SendToFolder = C:\Documents and Settings\Paul\SendTo\
Property(C): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(C): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(C): System16Folder = C:\WINDOWS\system\
Property(C): SystemFolder = C:\WINDOWS\system32\
Property(C): TempFolder = C:\DOCUME~1\Paul\LOCALS~1\Temp\
Property(C): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(C): USERPROFILE = C:\Documents and Settings\Paul
Property(C): WindowsFolder = C:\WINDOWS\
Property(C): WindowsVolume = C:\
Property(C): PackageCode = {B8281B75-6136-4DE5-A232-EB836CC79752}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = D:\DWF\LEA\DwfConvert\Installer
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 1500
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 3.00
Property(C): WindowsBuild = 2600
Property(C): ServicePackLevel = 2
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): RemoteAdminTS = 1
Property(C): NetHoodFolder = C:\Documents and Settings\Paul\NetHood\
Property(C): PrintHoodFolder = C:\Documents and Settings\Paul\PrintHood\
Property(C): RecentFolder = C:\Documents and Settings\Paul\Recent\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): Intel = 6
Property(C): PhysicalMemory = 1023
Property(C): VirtualMemory = 1761
Property(C): AdminUser = 1
Property(C): LogonUser = Paul
Property(C): UserSID = S-1-5-21-861567501-1682526488-1957994488-1003
Property(C): UserLanguageID = 1033
Property(C): ComputerName = PYTHON
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 1400
Property(C): ScreenY = 1050
Property(C): CaptionHeight = 33
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 20
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): MsiNetAssemblySupport = 1.1.4322.2032
Property(C): MsiWin32AssemblySupport = 5.1.2600.2180
Property(C): RedirectedDllSupport = 2
Property(C): Time = 11:16:44
Property(C): Date = 3/21/2005
Property(C): Privileged = 1
Property(C): DATABASE = C:\DOCUME~1\Paul\LOCALS~1\Temp\43226d3.msi
Property(C): OriginalDatabase = D:\DWF\LEA\DwfConvert\Installer\DWFConvert Setup.msi
Property(C): SOURCEDIR = D:\DWF\LEA\DwfConvert\Installer\
Property(C): VersionHandler = 3.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
=== Logging stopped: 3/21/2005 11:16:45 ===
MSI (c) (DC:20) [11:16:45:132]: Grabbed execution mutex.
MSI (c) (DC:20) [11:16:45:152]: Cleaning up uninstalled install packages, if any exist
MSI (c) (DC:20) [11:16:45:172]: MainEngineThread is returning 1603
=== Verbose logging stopped: 3/21/2005 11:16:45 ===
PaulLimburg
Error 2732
Post by PaulLimburg » Mon Mar 21, 2005 9:52 pm
Further to the previous message in this thread:
Cata:
At the failure, it looks like the msm module is trying to set some user profiles that require the Directory manager. But the Directory manager is not initialized. Without the msm module included, the next step in the log file is setting the TARGET DIRECTORY and the costing functions.
From MSI reference:
2732 "Directory manager not initialized".
The directory manager is responsible for determining the target and source paths. It is initialized during the costing actions ( CostInitialize action, FileCost action, and CostFinalize action.) A standard action or custom action made a call to a function requiring the directory manager before the initialization of the directory manager. This action should be sequenced after the costing actions.
Should the msm be able to assume that the directory manager is already initialized, because the Costing functions have already taken place?
Or should the msm module be doing something itself, such as costing, to initialize the directory manager?
Paul Limburg
PaulLimburg
Error Coce 2732
Post by PaulLimburg » Tue Mar 22, 2005 8:44 am
Cata,
Further to the previous 2 posts in this thread:
I've talked to the msm supplier.They say this problem occurs because the MS msi tools process merge modules before doing disk costing, which installs the directory manager. Other installers don't do this.
Is there some way to force disk costing before the installer processes the merge module?
Paul Limburg
Cata
Contact:
Post by Cata » Tue Mar 22, 2005 4:41 pm
Hi Paul,
Since DirectoryManager is initialized by CostInitialize I think that any standard or custom action that needs DM to be initialized should be scheduled after CostFinalize.
Advanced Installer uses sequence tables as recomended by Microsoft so I would say that the merge module should be changed. But which "other installers" is he referring to?
Then the only solution is to change the resulting MSI created by Advanced Installer with ORCA and move the actions that trigger the error after CostFinalize.
Question: Can you send us the resulting MSI (with the merge module included) but with no files - make an administrative image, this way it can not be installed - but we can look at its sequence tables?
Cata
dchinoraks
Post by dchinoraks » Thu Jun 22, 2006 7:11 pm
I have created a SETUP.exe for my Package Tracking System using Symbol Scanner Pocket PC 8846 in VB.net 2003 to be deployed on a client PC. I followed the instruction on the SF_MobileApp_Guide.pdf. Setup the redistribution kit and did the install all those files.
When I tried to install a Setup for Package Tracking System on a client computer, it gave me error. "The Installer has encountered an unexpected error initialing this package. This may indicate a problem with the package. The error is 2732"
That error 2732 is relating to Windows Installer below:
From what I understand, when I do a setup in VB.net, it creates a setup.msi file. I downloaded ORCA from Microsoft and tried to edit setup.msi file. One article on the internet suggested that it might SystemFolder in .msi file but it is correctly addressed in .msi file. What is it in .msi file that I need to fix?
I installed C:\Program Files\Common Files to a client computer by using vb.net setup program,the Setup.exe installed and regsvr32 just fine. Is it .MSM file that is causing me a problem?
I hope someone has an idea how to fix .msi file so I can install it to a client pc.
David
Post Reply
