MattFW
User prompted to reinstall when starting an installed app.
Hi there,
I've been distributing a product with an installer built with AI for a while now and I've had some reports from users that if they install it, move the shortcuts that were added by the installer to their start menu, then start my app (on Vista or XP), the installer appears and prompts for a repair.
I have been unable to replicate this locally and I've tried different permissions levels in case there's some kind of administrative switch that monitors where items were placed.
Does anyone know what could be causing this? The app itself doesn't do any checking of that kind of thing, and doesn't attempt to maintain any links to the installer internally so I'm not sure what could be causing it. I'm hoping there's a switch somewhere in AI that I just didn't understand and forgot to turn off. Any help would be much appreciated!
Cosmin
The repair is triggered by Windows Installer because a key path for a component is missing. This usually happens for advertised shortcuts that are moved from the original installation folder. You can read more about this here:
http://msdn2.microsoft.com/en-us/library/aa371546.aspx
There is a similar discussion on the forum, please take a look:
http://www.advancedinstaller.com/forums ... ove+repair
Cosmin
