icke_qps
"Shared legacy" components
I have been reading up on using "shared legacy" components, as mentioned in the help and some topics: viewtopic.php?f=2&t=10407&p=28060&hilit ... acy#p28060
So I already know that using the same MergeModule in 2 different installers will take care of the reference count and uninstalling.
We are still in transition of 'Visual studio deployment projects' and I would like to gradually move some projects.
Now I have this scenario:
- I have a Mergemodule compiled with AdvancedInstaller
- This merge module is used in an Installer built with Advanced Installer
- This merge module is used in another Installer built with Visual Studio
Does 'shared legacy' still work in that case?
Peter
Re: "Shared legacy" components
Hi Peter,
Yes, the reference count for the components (shared legacy) should work regardless the installer authoring tool. Did you encounter any problems with this?
