adamp88881
Digital signature cert per build or workaround
It would be nice if there would be an option to set different digital signature certificate for each builds.
Or a workaround could be a pre-build event which can run before the certificate import (now im using AI Pro 15.3 and the build specific pre-build events runs after the certificate import). With this workaround i could be able to replace the necessary certificate for each build.
Adam
Re: Digital signature cert per build or workaround
Hello Adam and welcome to Advanced Installer forums,
In what regards your request, indeed, as for this moment, this is not possible. However, I have added this on our TODO list and we will further investigate if it is possible to achieve this.
I will update this thread as soon as we will have a conclusive answer to this. Thank you for your patience.
Return to “Feature Requests”
