jstuardo
SQL Server error when installing
I am running an installer in a Windows 10 machine.
That installer connects to a SQL Server machine and creates a database and schema.
First I choose Trusted Connection but the attached error is shown. "Servidor Media" is the local user of the machine. When I user SQL Server Management Studio, I can connect correctly to the database and create tables.
More strange thing. When I don't choose trusted connection, and uses sa user with the password, the exact same error occurs.
I am also attaching the AIP file and the LOG.
What is going on?
I have tested in another PC and the same problem occurs.
Definetely it is not a problem in SQL Server installation. I can connect to the SQL Server instance using that user with SQL Server Management Studio. I tried with creating an ODBC data source with trusted connection and it worked too.
It seems Advanced Installer does something wrong that I don't know. Please tell me how to fix this.
Regards
Jaime
SQL installer error.png (45.84 KiB) Viewed 2424 times
install.log
(765.93 KiB) Downloaded 267 times
setup.aip
(82.78 KiB) Downloaded 296 times
Re: SQL Server error when installing
Hello Jaime,
This may happen because you do not have the "Trusted Connection (Windows integrated authentication)" option checked. Could you please check this option: SQL Databases --> "Base de Datos" --> check the option and see if that helps?
