hsc
Description text in ConfigureDlg
our installer should offer the user to optionally associate a file extension with the program being installed. I created a component "File Associations" to achieve this, with a lengthy "description". The ConfigureDlg displays "File Associations", rather than the description. Is there a way to change this?
Edit: It looks like I started in the wrong place. My new attempt is to add a file association "in a separate feature". The question remains: How to use the description text in the GUI?
Thank you
Hans
Re: Description text in ConfigureDlg
Hello Hans,
Please keep in mind that the text that you input in the "Description" field from the "Organization" page is meant to appear in the Customize Dialog ("CustomizeDlg" from "Dialogs" page - under "Maintenance") when the feature is selected in the features tree:
Basically, this is meant to appear during Maintenance only - when you go to Control Panel -> click on your app --> "Change" --> "Next" --> "Modify" --> select the feature.
Unfortunately, I am not aware of any way in which you can display the feature description in the "ConfigureDlg" dialog. I will try to dig this a bit further and if I will find something useful, I will come back to you.
