zeiddev
Appending to XML file
I have the following XML which I have abbreviated for simplicity:
<CustomDataSourceDS>
<CustomDataSource>
<FriendlyName>XX</FriendlyName>
<Creator>DZ</Creator>
</CustomDataSource>
<CustomDataSource>
<FriendlyName>YY</FriendlyName>
</CustomDataSource>
It is possible that there will be other CustomDataSource entries from other creators. I would like to add mine if the friendly name entry does not already exist. However I am not sure how to get the conditions to look forward. I am using the XML editor to add these nodes as shown:
Annotation 2019-05-29 101446.jpg (55.84 KiB) Viewed 3739 times
zeiddev
Re: Appending to XML file
Any thoughts about this???
In order to achieve this, I think that you can create an XML search (which will perform a search for your entry) and then use the result of your search as a condition. For more information, also please have a look on our "XML Search Properties" article which I think you may find useful.
