Hello Jaime,
Yes, it is possible to update this quickly if you remember where the initial folder was located. It is possible to achieve this through path variables.
Let's work through this with an example so you can better understand:
Let's say we have a folder containing three files:
- Capture.PNG (216.27 KiB) Viewed 5477 times
After that, let's say that we move our "Original" folder from desktop to "C:\".
Now, in order to not have to manually point for each file, here is how we can proceed:
1. Create a dummy folder in the original location. In our example, the original location was on desktop, so we will create the folder on desktop.
2. After doing so, please open Advanced Installer -->
"File" -->
"Settings" -->
"Path Varaibles". You should see a dialog like this:
- Capture1.PNG (10.42 KiB) Viewed 5477 times
3. In order to create a new path variable, click on the
"New..." button.
4. Give the Path Variable a name and then press on the
"Select" button -->
"Folder on disk...":
- Capture3.PNG (10.17 KiB) Viewed 5477 times
5. Now select the dummy folder that we have created earlier:
- Capture4.PNG (275.35 KiB) Viewed 5477 times
6. Click
"Ok"
7. Click
"Ok"
8. Now we should "update" our path variable to point to the location where we have moved the folder. To do so, please click on the
"Wizards" tab from the toolbar and then click on the
"Convert Paths":
- Capture5.PNG (24.44 KiB) Viewed 5477 times
9. In the spawned Wizard, click "Next". The Wizard should auto detect the paths that you want to convert, like this:
- Capture6.PNG (18.32 KiB) Viewed 5477 times
10.
"Next" --> "Next" --> "Next" --> "Finish"
11. Now it is time to modify our path variable to point to our new location. To do so:
"File" --> "Settings" --> "Path Variables" --> double click on the path variable we have earlier created --> "Select" --> select the folder that you have moved -->
"Ok" --> "Ok".
12. Build the project.
