How to link Installer Analytics with the installer
In case you have a subscription for Installer Analytics and need to link to your installers here's more details.
In the Analytics view from Advanced Installer you can track your installations, just enable the Installer Analytics. Once the checkbox has been enabled, an ID will be generated for your application, its tracking code.
Analytics view.png (11.51 KiB) Viewed 190467 times
By default, each application is public, it does not have an owner. That means, anyone that has the link can see its reports:
https://installeranalytics.com/app/#/ap ... phic/world
Geographic report.png (25 KiB) Viewed 190467 times
At this step, if you don't have an account, you can Sign Up or Login if you have an account:
https://installeranalytics.com/app/#/login
To get your application to your account, the following approaches can be used:
1) Import application
For registered users, when seeing the reports for a public application you have the option to Import application:
Import app.png (7.09 KiB) Viewed 190467 times
After this step, the application will be imported to your account.
2) Create a tracking code in the Analytics account
You can create a tracking code for your application that will be used in your Analytics account, removing the default generated one:
Create App.png (6.4 KiB) Viewed 190467 times
Enter a name, how you will name your application e.g. its name from ProductDetails view.:
Create App name.png (8.81 KiB) Viewed 190467 times
Once you do this, a tracking code will be generated for you. You need to use this tracking code in the Analytics page. Copy the Tracking Code generated from your Analytics account so that you can track the installers that you want.
Generated Tracking Code.png (34.15 KiB) Viewed 190467 times
Just use this code in the Analytics page and rebuild your project. The first generated code is mostly for testing purposes, as you don't really need an account on our Analytics page so that you can see information regarding installation.
The Installer Analytics will start to send information regarding installation on your account, no more public apps.
After copying the code from your Analytics account from the web, the Analytics view should be like this:
Analytics view new code.png (10.69 KiB) Viewed 190467 times
Notice please that the first generated tracking code was removed, and the one from my Analytics account is being used.
Also check our How it works article from the Installer Analytics website.
Return to “Sample Projects”
