MLiss@Cetrus.com
Suite installer - relative path for prerequisite installer
I am looking at the instructions for the suite installer, it indicates to add other setup packages (or msi files)
I press the file selector button and chose a file, but after that, the "File Path" cannot be edited in the "setup files" tab
( I want to set a relative path )
All of my installers are Advanced installer projects, but they are built automatically by Team city on our build machine:
How can I specify a relative path for the suite installer to pick up the installers (or for that matter, pick up the installer from another drive )
for example: ..\..\Myinstaller\Setup Files\MyInstaller.msi
Re: Suite installer - relative path for prerequisite installer
Hello Mike,
By default the prerequisites setup path is saved in our setup project as a relative path. The path is relative to the setup project root path which actually is the parent folder of the .AIP project file. So basically you should just make sure the prereq setup file it is imported on your TeamCity repository with the same path structure relatively to your .AIP project file.
Also, if you need to update the prerequisite file path by command line then you can use our "UpdatePrerequisite" command.
