MLiss@Cetrus.com
Suite installer - dynamic application settings dialog
I have a question about how to setup the installer to dynamically display only the dialogs for the applications that are to be installed.
In your suite installation example, there are three installers used : LicenseManager, App1 and App2.
The suite install has a dialog that allows the user which application to install
When I ran the install, and left App2 unchecked, indicating I did not want the second app installed:
However, when I clicked next, it still brought up the dialog for App2 settings?
How can I configure the dialogs to only appear for the applications that are to be installed?
In other words, I only want application 2 dialogs to be shown when application 2 is installed.
Re: Suite installer - dynamic application settings dialog
Hello Mike,
To achieve what you want you should use our "Show only if" option as it is exposed on "Always Custom in Professional setup" thread by my colleague Mihai.
