belsonmarble
Updater - Calling via command
When you call the updater am I just calling the updater.exe or am I having some code run so its a silent install? Plus with the current application still open, the application will need to be closed in order to install the updates, how is this achieved?
Re: Updater - Calling via command
Hello Belson,
Please have a look on our "Updater" article. There you can see what are the "updater options" that can be passed to our updater.
In what regards your second question, you can use the "Auto Close Application" tab from your "Updates Configuration Project".
This tab will let you specify what applications you want to be closed during the update process.
