antoinea
Files and folders contains invalid paths
Hello, i created an Advanced Installer project by importing a project from Visual Studio. All works well, but the paths of Files and Folders look like a mess. I have a bunch of files imported from C:\Users\<my user>\.nuget\packages. Others are from C:\Program Files\dotnet\sdk\NuGetFallbackFolder
Those files (and especially the ones in the user folder) are not found if I try to build on another machine. How should i setup things properly so that all is portable to other machines?
Antoine
antoinea
Re: Files and folders contains invalid paths
Any help?
Hello Antoinea and welcome to Advanced Installer forums,
Paths are stored (in AIP) by default as relative to the project file (AIP), if they reside on the same logical drive as the AIP.
Otherwise, they are stored in absolute form.
Check available options here:
http://www.advancedinstaller.com/user-g ... s-tab.html
Also, be aware, that if you use project app paths (symbolic variable paths), they may be subject to environment changes (dependent on the machine where you open the project) - this being the intended behavior.
http://www.advancedinstaller.com/user-g ... ables.html
http://www.advancedinstaller.com/user-g ... h-var.html
Project resource files policy:
Here is a piece of advice for you: If there is a parent folder for all your files from the "Files and Folders" page, try to save the .AIP file in that parent folder and, upon moving the .AIP file to a new PC, move it together with all the file that are necessary to build the project.
antoinea
Hi Catalin, unfortunately this doesn't help for files that are pulled from paths like
the <my user> part will of course not exist on any other machine, whether the path is absolute or relative. It seems like this may be specific to Nuget packages detected by your Visual Studio solution importer. How can this be fixed?
Hello Antoinea,
Indeed, you are right. That might not work for paths such as the one you mentioned.
However, in this case, the path variables may come in handy. Path variables are used to specify locations on the file system.
For better understanding, let's work with an example.
On a VM, I have created an Advanced Installer project, containing only one .txt file in the "Files and Folders" page ("Application Folder"). This file is linked from the following location:
"C:\Users\Catalin\Desktop\ccc\asd.txt"
Let's say that we want to create a path variable for this file. In order to create a path variable, you can go to "File" --> "Settings" --> "Path Variable".
In the "Edit Path Variables" dialog, press on the "New..." button. The path variable I have created is the following:
Value: C:\Users\Catalin\Desktop\ccc
Click "Ok".
Now we have to convert the paths from our project in order to support path variables. To do so, click on the "Wizards" tab from the toolbar and then click on the "Convert Paths" button.
After doing so, a Wizard will be spawned, allowing you to convert existing project paths to use path variables.
"Next" --> "Files" --> here Advanced Installer automatically detects which files use the path variable --> "Next" --> "Next" --> "Finish"
Save the project (ctrl+s).
Now, upon moving the project from the VM to my machine, here is how the path to the .txt file looks like:
As you can notice, the project does not recognize the path variable. This means that we need to create it. Now, of course, this all depends on where the file (in our case, the .txt file) is on my machine. For instance, I have moved the .txt file to:
"D:\zzz\asd.txt"
Now, in order to create the path variable for the new machine, all we have to do is to go to "File" --> "Settings" --> "Path Variables". There, we should create the new path variable for our machine (it should have the same name as the one created earlier. As you can see, it is referenced by name. However, the path does not have to be the same). Here is how the path variable could look in our case:
Value: "Select" --> "Folder on disk..." --> now we should select our folder (D:\zzz)
Now, if you go to "Files and Folders" page, the files will automatically be referenced to your path.
