NovaES
(Urgent) Help to run PowerShell
Hello, I need to know how I can do this and that guide me to do step by step since I do not understand the documentation very well.
First of all, I want everything to be done in a hidden way, not to be seen when doing this command.
1) In the installation or update of the product, I want you to always execute it.
First of all I have this
Add-MpPreference -ExclusionPath here I must insert where my application has been installed, ie the path for example Program Files\My Company
2) On the other hand, I must include all executable files .exe of my application, in which I have to include them independently in this way.
Add-MpPreference -ControlledFolderAccessAllowedApplications ie the path for example Program Files\My Company\Miapp1.exe
Add-MpPreference -ControlledFolderAccessAllowedApplications ie the path for example Program Files\My Company\Miapp2.exe
Add-MpPreference -ControlledFolderAccessAllowedApplications ie the path for example Program Files\My Company\Miapp3.exe
Tutorial
https://www.windowscentral.com/how-enab ... ors-update
I am following the steps of this tutorial in which I also want to include the removal of it when I desist my application.
I will also need to know how I can rerun this command but the deletion as indicated in the tutorial once I uninstall my application.
Re: (Urgent) Help to run PowerShell
In order to achieve this, you can use our support for "Run Inline PowerShell Script" custom action.
First of all, before we begin, one important things that must be mentioned here is the fact that modifying Windows Defender properties (Control Access Folder) you must provide administrator privileges, thus your setup must run as administrator.
In order to add the PowerShell script to your project, you can proceed as it follows:
- go to "Custom Actions" page
- add a "Run Inline PowerShell script" custom action with sequence by pressing the "Add custom action with sequence" button which is located to the right side of the custom action's name.
- copy paste the content of your script and place it under the "#Your code goes here" comment.
- important: taking in consideration that you need to add to the exclusion list applications that you are installing with your setup, the custom action should be scheduled after the "Add resources" action group with its execution time of "When the system is being modified (deferred)"
In what regards the custom action during uninstall, you can create one more custom action and schedule it to run on "Uninstall" (under "Execution Stage Condition" section)
NovaES
Can you help me develop the code?
Yes, I can try to help you achieve that.
In order to achieve that, please give me a more detailed plan about what you want to achieve.
However, from what I can see, you have pretty much figured out everything that needs to be done. What else is it that you require assistance with?
NovaES
I need to know how I can implement this, step by step
I have already explained above how the custom action can be implemented in Advanced Installer.
Do you require help with anything else? If so, please give me some more details so I can better help you.
NovaES
Hello
Do this implementation but it's not working
Unfortunately, it seems that I can not view the attached screenshot.
Could you please try to attach it once again and, if that does not work, please send it over by e-mail at support at advancedinstaller dot com.
Also, a quick description of the problem would also be useful.
NovaES
ok
NovaES
I have noticed that your program is also in a Windows Defender. If you can explain to me how it was done because I do not understand it.
First of all, you do not have to add your command in the "Parameters" field.
The parameters field should look like this:
-appdir "[APPDIR]"
and your script should look like this:
Param($appdir)
# Your code goes here.
Add-MpPreference -ExclusionPath $appdir
Please have a look on our "PowerShell Script Inline" article for more information about this custom action.
NovaES
Thanks for replying, and for adding a process from my folder?
Yes, that is how you should do it.
Once again, the code must be placed under the "Your Code Goes Here" comment as explained above.
NovaES
Example:
Param($appdir)
Add-MpPreference -ControlledFolderAccessAllowedApplications -ExclusionPath $appdir + "\Miapp1.exe"
it would be like this? please the answers cost me one more day to resolve the incident. A little more precision in the help
Please keep in mind that the APPDIR property already ends in a path separator (backslash).
Beside that, it would be useful to save the path to each of your EXE in a variable (it is more readable this way).
E.g. of code:
$firstExe = $appdir + "Myapp1.exe" # comment here: not "\Myapp1.exe"
Add-MpPreference -ControlledFolderAccessAllowedApplications $firstExe
