jstuardo
I need to run a custom action BEFORE starting a Windows Service
I developed an application that has a Windows Service.
The installer has a custom action that modifies the configuration file of the service in order to set the correct database connection string.
The problem is that the service tries to be started before the custom action, so it obviously crashes because there is no connection string configured.
At what stage can I run my custom action to ensure it is run before the service is going to be started?
Currently I have placed it after "Finish Execution" stage.
Regards
Jaime
Re: I need to run a custom action BEFORE starting a Windows Service
Hello Jaime,
A service is installed during the "Add Resources" action group --> "InstallServices" standard action.
In order to schedule your custom action before the "InstallServices" custom action, you can proceed as it follows:
1. go to "Custom Actions" page.
2. under "Install Execution Stage" --> right click on "Add resources" action group --> "Show Standard Action" --> "Add Resources" --> click on "InstallServices"
After that, simply schedule your custom action by drag & dropping it to the appropriate point.
If you need to run it before starting the service, you can proceed the same as above, but simply replace the "InstallServices" standard action with "StartServices" action.
jstuardo
sorry but that did not work.
After some attempts, I am attaching final configuration.
The script is always run before copiyng the files.
Regards
Jaime
jstuardo
Something is coming to my attention.
As other attempt, I added my custom script after Start Service stage.
I see in the wizard window the status "Starting Services", and then my message box is shown (see the picture).
Then, all files started being copied. And after that, I see the status "Starting Services" again and my message box did not appeared again. What is going on?
Regards
Jaime
starting services.png (70.53 KiB) Viewed 10515 times
Hello Jaime,
I forgot to mention this in my last thread, but the "InstallService" standard action takes place during the deferred stage.
With that being said, your custom action must have its execution time set to "When the system is being modified (deferred)".
You are always welcome, Jaime!
jstuardo
Hello Catalin,
something happened that this does not work anymore.
I am attaching the AIP file.... I have checked and re-checked that the configuration of custom action is correct, however, it is not executed before installing the service.
Regards
Jaime
Control de Visitas 3.aip
(93.25 KiB) Downloaded 347 times
jstuardo
it turned out that the VBS file had a syntax error.
Unfortunately, Advanced Installer log does not log that, even when I checked the "Enable verbose logging" option. I think this kind of errors should be logged to make error causes easier to find.
Regards
Jaime
Hello Jaime,
I am glad you found the culprit and that everything works as expected now.
In what regards the logging, unfortunately, since every script is custom made, Advanced Installer cannot log it (since every script can be created differently - for instance, a script can return some value in a failure scenario, whereas another script can return another value, all being up to the user that creates it).
However, if you need to write some events to your VBScript file (that can help when debugging), you can follow the approach described in the "How to write a specific event in the log" article.
jstuardo
Dear Catalin,
Of course Advanced Installer cannot log what is inside the VBS execution, but it seems I wasn't very clear.
The problem was a syntax error in the VBS file not allowing the script to run. That error could be logged, actually.
I realized about this when trying to execute the VBS script from outside Advanced Installer by using cscript utility. As you may know, a VBS script is compiled just before it is run, so, when using cscript utility, the syntax error was shown immediately before the actual execution.
Advanced Installer should do the same. It is launching the VBS script somehow by using some utility. That utility should throw any syntax error present in the script but the problem is that this does not happen.
Regards
Jaime
Hello Jaime,
Thank you for the explanation on this.
I have added your request on our TODO list of improvements and hopefully this will be added in a future version of Advanced Installer. Thank you for bringing this to our attention.
I will update this thread as soon as the improvement will be implemented.
