harshal119
Using StartMenuShortcutDlg with Customized name
Hi team,
We would like to use the StartMenuShortcutDlg to ask user for specific name for Desktop shortcut. We are able to add that dialog in MSI package. However, we would like to create the shortcut with the selected/entered name on that dialog. We would appreciate any help or steps to achieve that. Thanks
Re: Using StartMenuShortcutDlg with Customized name
Hello Harshal,
I am afraid that is not possible. Please let me explain why.
Let's start with what a property is: Properties are global variables used by Windows Installer during an installation. Their values can be set by the operating environment or by authoring them into the installation database. Properties can be used inside Formatted Type fields with the format [PROPERTY] and they will be replaced at install time with the value associated with the property's name.
The "Name" field from the "Edit Shortcut Properties" dialog:
is of PseudoFormatted Type. A PseudoFormatted Type property's value is resolved (set) at build time, which makes it impossible for you to set its value during install time (e.g. user inputs a value and shortcut's name becomes that value).
Please let me know if there is anything else I could help you with and I will be glad to assist.
