Hello Jacob,
if I'm supposed to, just say the word and I'll open the topic!
Don't worry, it is fine like this as well, you don't need to create a new topic.
In what regards your question, I am not quite sure I understand the scenario.
From what I understand, you want to force the user to choose another path than the default one?
For instance, let's say the default path is set to:
C:\Folder1\
You want to disable the
"Install" button if the user does not change that default path (by the way, the default path can be found in
"Install Parameters" page -->
"Application Folder:" field)
If that is the case, we can proceed as it follows:
1. First of all, the property that stores the value of the
"Path Edit" is named
APPDIR
2. We can retrieve the default value of the APPDIR property by running the setup once and, during the
"FolderDlg", we can copy its default value. For instance, the default value in a newly created project will look like this:
C:\Program Files (x86)\Your Company\Your Application\
3. After doing so, we can create a control condition which will disable the
Install button if the
APPDIR is equal to that default value (
if the user did not modify its value)
4. To do so, we can proceed as it follows:
- open your project and go to
"Dialogs" page.
- from the dialogs list, please select the
"VerifyReadyDlg" dialog.
- click on the
"Instlal" button
- select the
"Control Conditions" tab and create a new control condition (
"New..." button) like it follows:
Condition: APPDIR = "C:\Program Files (x86)\Your Company\Your Application\"
Action: Disable
- Capture.PNG (95.1 KiB) Viewed 5357 times
If this is not what you meant, please give me some more details so I can further assist you.
