Hello Albert,
Use case: Let's say that we have a property as it follows:
Value: Hello
In order to localize its value, you can proceed as it follows:
1. go to "
Install Parameters" page
2. double click on the earlier created property
3. right click on the value field -->
"Localization..." and select the following option:
Always translate this string - Using default localization identifier
4. click
"Ok"
After doing so, please go to
"Translations" page -->
"Project Strings" tab and set the property value for your language.
Every localized property will have a
Localization ID. For instance, the Localization ID for our earlier created property will be:
Property.MY_PROP
For instance, if we have two languages for our projects, i.e. English and French, we will have to set the localized property's value for the french as it follows:
- Capture.PNG (44.37 KiB) Viewed 4138 times
- Capture1.PNG (40.74 KiB) Viewed 4138 times
More information about localized strings can be found on our
"Localized Strings" article.
