srujan.palakurthi
VBScript to create installer property
is it possible to create installer properties using VBscript?
srujan.palakurthi
Re: VBScript to create installer property
can you please suggest on this.
Hello Srujan,
For more information about this, please have a look on our "Get and set a property in a Visual Basic and Java scripts custom action" article which I think you may find useful.
srujan.palakurthi
Thanks for your response, i have also followed same but the script is failing to execute at run time, that is because of ; at the end.
but finally figured it out and now i am fine.
Srujan.
You are always welcome, Srujan.
Glad to help.
Indeed, it seems to be a wrong ";" in the code. I will forward this to our Technical Writing team so they can edit the content.
