Rik HS
Minor Update handling in Bootstrapper
We would like, if possible, handling of the Minor Update scenario (same product code, increased version number) to be supported by the bootstrapper.
There is a situation where we do not change the product code (to allow for patch file creation) but where the MSP may be used on machines where a previous version is present or for a clean install (beta versions, new release to manufacturing, etc).
If the bootstrapper could automatically detect the Minor Upgrade scenario and invoke the MSP with the /fvomus flag to execute a Minor Upgrade that would be really usefull. We cant embed /fvomus in the setup.ini as it then won't do a clean install.
The current situation requires users to remove the old application first, or invoke the installer with command line switched - neither of these is very friendly.
Ionut
I have added this on our TODO list. Thank you for your suggestion.
Ionut
Denis Toma
Advanced Installer Team
Return to “Feature Requests”
