rami vemula
Maintainance Dialog UI Distortion
Hi All,
I created a basic AIP with some custom prerequisites. Installation working fine. But when I do Uninstall/Repair from Control panel. I do see below UI.
Any pointers to resolve this issue is highly appreciated.
I am using AI 16.1.
Rami.
rami vemula
Re: Maintainance Dialog UI Distortion
Fixed this problem by selecting 'Always (install, uninstall and maintenance)' option under settings tab of Themes section. This setting should be checked explicitly if Black Surface theme is opted.
Hi Rami and welcome to our forums.
Indeed, the "Always (install, uninstall and maintenance)" option should be selected under "Themes" page, "Settings" tab when the "Surface" theme is used. Actually, this option is set automatically when this theme is selected and I'm not sure how it got unset for you.
If you have other questions, just let us know.
