jfhb
I meet issue about the PrintButton! It ca't print all agreement document.
Capture as below:
Print end at list item 17.
can't print all document.png (31.34 KiB) Viewed 4102 times
Our agreement document filesize is 152.3 K. and now it only print to item 17.
we total got 28. yeah, 27 is around 70% of the file.
full print size copy to a text editor, i can see it's total size is: 32591.
is there some limit on the print size? Or any suggestion to resolve this case?
User just ask for us why it can't print full agreement...
Thanks.
jfhb
Re: I meet issue about the PrintButton! It ca't print all agreement document.
Anything need me, please let me know. :D
Please help.
I attach some capture for the print setting:
only a printButton, no other actions to this dialog.
can't print all document.png (78.88 KiB) Viewed 4101 times
Display is ok on the dialog
can't print all document.png (111.88 KiB) Viewed 4101 times
This was, indeed, an Advanced Installer issue fixed in version 16.0. Do you still encounter this problem in the latest versions of Advanced Installer?
jfhb
Thanks Eusebiu.
I will testing the DLL from you.
Thanks again.
You're welcome. Just let me know if you encounter any problems.
