Alext
CA during install & uninstall
Pretty new at building Msi. :oops:
I need advice for my simple project.
I need to run an exe (installed by the msi) with some arguments at install.
I also need to run this same exe but with other arguments at uninstall.
Someone can point me in the right direction ?
Cheers,
Re: CA during install & uninstall
Hello Alex,
In order to achieve this, you can use our predefined support for the "Launch File" custom action. This custom action lets you specify the arguments you need to pass through the "Command line:" field.
Also, in what regards the execution stage, you can either set it for "Install" or "Uninstall" from under the "Execution Stage Condition" section:
