ruck64
Multiple EULA's
Im trying out the professional version of AI. So maybe I need to use the bootstrapper for this.
Essentially I have three EULA's that need handled. Once I add on from the add dialog menu I can't add any more. Which thats fine since it states in the help I can create a new dialog. It does state that sometimes it maybe be disabled, which in that case I would assume that option would appear some where on the dialogs tools yet its no where on there. And hitting the insert key does nothing either. This is all on the first time install folder since I dont want them to be able to install it without first agreeing to the EULA's. Maybe someone can tell me if I need to use the bootstrapper or if Im maybe just missing something some where. :?:
Re: Multiple EULA's
First of all, thank you for trying out Advanced Installer.
To be fully honest with you, I am not quite sure I understand what you mean here. Could you please give me some more details about what you want to achieve (maybe exemplify)?
From what I understand here, you want to have 3 EULAs in your project and show them based on a condition. Am I right?
If that is the case, then indeed, you may need multiple dialogs to do so.
If by this you mean that you want to "disable" (hide) a dialog, then I am afraid that this is not possible with the Professional version. In order to be able to edit dialogs (use the "Dialog Editor" feature), the Enterprise version is required.
Again, I may have misunderstood your scenario. If that is not what you mean, please give me some more details so I can try to help you.
ruck64
Re: Multiple EULA's
Sorry I didnt even get notified this was posted. Or that it had a comment on it.
Sorry if I was unclear in how i presented my dilemma. My goal is to have the user agree to 3 different EULA's
As it currently stands I only see the option to have one EULA in place. I have looked for New Dialog in that page but the only options that are even visible are add dialog and delete. I dont see any option to add an additional dialog.
Given that I dont have any set conditions. I would like these to be mandatory just like the first one. Just with different wording.
Also is there a way I can get notified that I get a reply to this thread?
Re: Multiple EULA's
First of all, thank you for your followup on this and for the explanation. Now things are more clear for me.
Indeed, in the Professional version, you can only add a dialog from our predefined list of dialogs (you can not create one. This is because creating and editing a dialog is part of our "Dialog Editor" feature, which is available starting from the "Enterprise" suite or above). Adding a predefined dialog is possible by using the "Add Dialog" button from the toolbar:
Setting a condition for your dialogs is not mandatory. I just thought that you may need to show the dialogs based on some conditions.
In what regards the post notifications, I think that this may be achieved if you press the "Notifications" button (the one with the bell near its name) --> "Board Preferences" tab --> "Edit notifications options" section:
ruck64
Re: Multiple EULA's
I appreciate that information. For testing purposes I have upgraded this one to enterprise since im still in trial mode. Is there any easy way to replicate and simply change the file its reading from without having to create the entire setup myself?
Re: Multiple EULA's
I am afraid that this is not possible. The "LicenseAgreementDlg" dialog only accepts as input a .rtf file - you can not have multiple .rtf files as input.
Since you have upgraded to Enterprise, a way to solve this would be to use the "Dialog Editor" feature to create multiple dialogs which replicate the behavior of the "LicenseAgreementDlg" dialog.
More information about the "Dialog Editor" can be found in our "Using the Dialog Editor" article.
ruck64
Re: Multiple EULA's
K thank you
Re: Multiple EULA's
You are always welcome.
