rafizan46
Use Static Text as Path Edit to dispaly install path
Hi, is it possible for me to use Static text as Path Edit to display the Install Direction? I already do it, The display text I put [APPDIR] , it display the default location, but the problem is, the static text not updating and not showing the new file location. Is there are ways to refresh the Static text automatically every time user try to change install path?
rafizan46
Re: Use Static Text as Path Edit to dispaly install path
Its ok, I already solve this problem.
Here what I do,
On Static Text subscribed Event,
Subscribe to: Display action text during install
Attribute to set: Text
Then I use VB Script to trigger Refresh the current dialog.
The script is here: https://www.advancedinstaller.com/user- ... ialog.html
You can then call this script by placing an Execute custom action published event on dialog Init Events.
The browse button added the Refresh the current Dialog event.
The static text Property Name is set to "MYPROP"
The display text is: [APPDIR][MYPROP]
Thank you for your followup on this and for sharing your solution with us.
I am sure this will be of help for further users facing a similar scenario.
It will definitely be of help.
Return to “Feature Requests”
