Acamori
Hot to edit updater.ini file ?
How i can set or edit entries in default .ini file which created by update programm feature ?
On this screenshot i not able to edit this file or his entries. How i can set -reducedgui flag to the DefaultCommandLine key ?
Screenshot
Screenshot
Re: Hot to edit updater.ini file ?
I have noticed something wrong with the user interface in your screenshot. Some of the text is translated even if it should not be.
Please keep in mind that the only location from where you should download Advanced Installer is our "Download" page:
https://www.advancedinstaller.com/download.html
With that being said, if you downloaded Advanced Installer from any other website, please uninstall it and download the installer from the above link.
