Abhinay
How to display the runtime message
How to display the runtime message on the message box of the installer.
PS D:\RSP Firmware Update\RSP_Firmware> $a = .\SinetProg.exe /i /a:192.168.29.20
PS D:\RSP Firmware Update\RSP_Firmware> Write-output "Your Current " $a[0] "and your current " $a[4]
Your Current
Device Type: SP650
and your current
Firmware Version: 1.1.73
Instead of Write-output i want it to be displayed on message box of the installer how to do that
I tried the code as below but it did not work, Can you help me with this
 [System.Windows.MessageBox]::Show("Your Current " $a[0] "and your current " $a[4])
Abhinay
Re: How to display the runtime message
I have tried the code, but it does not work
# Block for declaring the script parameters.
Param()
   # Your code goes here.
Add-Type -AssemblyName PresentationFramework
cd "C:\Program Files\Weir Minerals\RSP Firmware\RSP Firmware\"
$rspIps = "192.168.29.20","192.168.29.21","192.168.29.22","192.168.29.23","192.168.29.24","192.168.29.25","192.168.29.26","192.168.29.27"
foreach ($rspIp in $rspIps)
   if (Test-Connection $rspIp -Count 1 -ea 0 -Quiet)
     if((($rspIp.Substring(11,2)) % 2) -eq 0)
	$a = .\SinetProg.exe /i /a:$rspIp
     if((($rspIp.Substring(11,2)) % 2) -ne 0)
	$b = .\SinetProg.exe /i /a:$rspIp
Write-output "Your Current " $b[0] "and your current " $b[4]
        [System.Windows.MessageBox]::Show("Your Current " $b[0] "and your current " $b[4])
   else
       [System.Windows.MessageBox]::Show($rspIp could not be pinged)
You can give me suggestions like if it can be displayed on message box or somewhere else
Hello Abhinay,
The message displayed by the Show() method must be included in " (quotes) if it contains any text beside your variables. Additionally, variables that are included in double quotes will expand their values at runtime. That means that you should not escape them in the Show() method. Here is a little example so you can better understand what I mean here:
$var1 = "there"
$var2 = "how are you?"
[System.Windows.MessageBox]::Show("Hello $var1 $var2")
The output of the above code will be:
Hello there how are you?
However, if we use single quotes instead of the double quotes (e.g. 'Hello $var1 $var2'), the output will be:
Hello $var1 $var2
Hope things are a bit more clear now.
With that being said, the input of your Show() method should be:
[System.Windows.MessageBox]::Show("Your Current $a[0] and your current $a[4]")
respectively:
[System.Windows.MessageBox]::Show("Your Current $b[0] and your current $b[4]")
Abhinay
It worked... Thank you
You are always welcome, Abhinay.
I am glad it worked.
