harshal119
PathEdit default value for Property base
How would I set default value to Path Edit textbox. I would like to point to default MyDocument directory of user as default and if user changes, it should be reflected too (means need property based)
Re: PathEdit default value for Property base
The default property for the "Path Edit" control (from the "FolderDlg" dialog) is APPDIR.
In order to change the default value, please go to "Install Parameters" page and input your desired path value in the "Application folder:" field.
harshal119
Thanks for quick response Catalin. However, I would need two different paths like below:
Is it possible to have another property say DATA_DIR and set my document as default value?
If you click on the EditBox control (as in your screenshot), on the right side, under the "Properties" section, you can notice more properties, such as "Identification", "Display", etc.
Under the "Property" section, you will see the property name and its default value. In the "Default Value" field, you can set the default value for your property:
harshal119
Thanks. Its working now. Appreciate your help
You are always welcome.
I'm glad I could help.
