harshal119
Unable to uninstall older version
Facing following issue while uninstalling pervious version from Control panel as well as using repair option.
Is there any way to uninstall forcefully previous versions?
Re: Unable to uninstall older version
In order to achieve this, you can use one of the solutions described in the "How do I remove a broken installation" FAQ.
harshal119
I am getting following error with /fv
harshal119
I am able to figure out the problem. I think the new version 16.2 (I updated in Morning) have introduced <ROW Action="RemoveExistingProducts" Condition="(AI_UPGRADE&lt;&gt;&quot;No&quot;)" Sequence="1402" SeqType="0" MsiKey="RemoveExistingProducts"/> in Custom action. And I am guessing its considering default condition as AI_UPGRADE="No" and that causes this side effect. When I changed that condition to UPGRADINGPRODUCTCODE it started working. Would you please confirm my observation. Thanks
Please make sure that you apply this command on an MSI package, not an EXE one.
I'm not sure why it started working after you changed that condition. The "AI_UPGRADE<>"No"" condition was always the default one for the "RemoveExistingProducts" standard action and it is not recommended to change it.
