Hi team,
We are building installer which assigns icons to specific type of files. like Icon A for .xxr extension. We are doing this using File associations. Its working as expected. I.e. assigns icons to respective extensions. However, we would like to achieve some different functionalities as below:
1. Give icon to specific file extension. already done as explained above
2. When user clicks these type of files, it opens our application as icons were assigned using our .exe as resource. We would like to prevent opening of application in this case. Therefore, if user clicks on such files, it should open either notepad or do not open anything or ask user to select application to open instead of just opening our application.
We would appreciate if you can suggest some way to achieve this.
