LloydAZ
UI Errors for Repair or Remove of Installed Instances
If I have multiple instances of the application installed on the same machine the UI breaks when trying to repair or remove anything other than the initial install. Here is the maintenance screen that shows two instances installed:
If I select the one named "NovusMED" (the initial install) I get the correct remove/repair screen.
If I select the one named "NovusMED Dev" (the second instance) then the UI of the remove/repair screen breaks.
I desperately need to get this fixed.
Re: UI Errors for Repair or Remove of Installed Instances
Hi and welcome to our forums.
I'm afraid that this is a "Multiple Instances" feature limitation. It is fully compatible only with the "Classic" theme which does not require the "Enhanced User Interface" feature.
