sreedevibalachandran
AutoUpdate issue - Urgent
I have created a 32/64 bit mixed platform type installer. It allows exe type build only.I have enabled autoupdater functionality too. But when the auto updater exe tries to download the main exe from a hosted server (hosted in IIS), it doesn't allow to download the exe (since it is an exe file). What should we do to solve this?
Re: AutoUpdate issue - Urgent
This might happen if the Firewall or the Antivirus is blocking the Updater from downloading your .EXE. Could you please try to disable the Antivirus and then proceed in using the Updater once again?
If the Firewall is the one blocking the Updater, then you could try to add an exception to your Firewall for it.
