Mark1701
Using updatable properties in shortcuts and registry
I'm trying to extract the major and minor version numbers from the ProductVersion property to create shortcuts, folders and registry keys based on the combination of major and minor.
I've tried to go though some of the existing posts threads but some are quite old and others don't really seem to solve my problem.
I've created two support properties:
MAJOR_VERSION
MINOR_VERSION
and used them as parameters for the creation of shortcuts, registry nodes, etc.
At the same time I created a custom action to run a script that updates those properties with the first and second parts of the ProductVersion field
This is my set-up for the Registry and it works well, the registry key is created with the correct major-minor value
This is my set-up for shortcuts and folders
... and it doesn't work since I end up with 0.0 as major and minor numbers
now I think this is caused by the fact that in this second case I'm using pseudoformatted properties (i.e. [|MAJOR_VERSION]) that are resolved at build time, while the custom action that populates the properties is executed at install time and it's helpful only for the registry.
but I couldn't find a way to use non pseudoformatted properties when creating folders or shortcuts, and scripts can't be run at build time.. so how can I solve this o_O ?
Re: Using updatable properties in shortcuts and registry
Hello Mark and welcome to Advanced Installer forums,
Please have a look on the following thread in which a similar scenario is discussed:
how to create MAJORVERSION.MINORVERSION folder under Application Folder.
Mark1701
Thanks for your reply.
I had a look at the list of steps from the other thread and they indeed produce a folder with the correct structure but I'm having problems with the shortcut creation. How can I create a shortcut with this structure:
[ProductName] [MAJOR_VERSION].[MINOR_VERSION]
under the Windows main menu and on the desktop?
The second problem is.. during the installation process users are prompt to choose a target directory, the suggested name does not match what I need but refers to the standard APPDIR and I couldn't find a way to change it (see picture below)
Hello Mark,
I am not quite sure I understand what you mean here. Could you please give me some more details about what you want to achieve (maybe exemplify - e.g. some screenshots)?
If I understand correctly, please correct me if I am wrong, you want to modify the APPDIR property during the install?
If that is the case, that can be achieved as it follows:
1. go to "Dialogs" page
2. select the "InstallDlg" and click on the "Install" button
3. under "Published Events" tab, create a new event by pressing the "New..." button, as it follows:
Set installer property value
Property: APPDIR
Argument: your path (even if it contains spaces, do not use quotes)
Condition: leave unchanged
This way, the APPDIR property can be changed during the installation.
If you want to change the default value of the APPDIR property (the one displayed as default in the "InstallDlg"), you can change it from the "Install Parameters" page --> "Application folder:" field.
