AdvancedTom
One project with different resource files for different builds
Hello experts,
I need some help with my project.
Following scenario:
I have one project and I want to create multiple builds, so far so good. But I want different resource files for each build.
One file should be changed in each build, i.e. for build A is file A and for build B file B is needed and so on and so on.
Unfortunately the build events doesn't work for me, because the path of the file I want to change for each build can be changed during the setup, so I need a variable for a file copy.
I can search successfully for the path in the registry, but if I use a search property as a argument variable for a build event, it is always empty.
Here is an example for my search in the registry: (I get an result as expected)
But if I try to use it as an argument in a build event, it returns nothing:
What am I doing wrong?
Is it possible to create such an project as I want, or am I totally wrong?
Hope you understood my problem and I hope you can help me.
Thank you for everything.
Greetings tom
Re: One project with different resource files for different builds
Hi Tom,
To achieve what you want you should just use the "Files and Folders" section of your setup project. Just add a file in "Files and Folders" page. Then double click on the added file and use the "Edit Source Path per Build" hyperlink option.
If this does not help you just give us more details about your requirement.
AdvancedTom
Oh Jesus, that was easy. That's it!
Thank you so much for your help and please excuse my stupid question.
You are always welcome and don't even worry about that Tom!
Do not hesitate to post your questions anytime we may have a doubt.
You are always welcome Tom.
